Why the circuit does not freeze/lock when the signals SUM ? But the electrical signals are SUM together in what sense?
This question is about neural network circuits because I don't understand what exactly at hardware level node is it
Is a line ?
I have a wrong image in my head about node concept because I translate like point:
if 10 machines meet at the same point or node occurs the incident, then how is adjusting the time within a neural network?
What happens inside a 'node' in artificial neural network ? Can you show me an example of hardware electronic circuit implementation about a neural network? a neural network?
Another suggest me this image to understand but I don't see circuit
a circuit with input terminals 10 to 10 independent signals.
But this is a line not a 'node'
I try to find a circuit for what you call 'node' about an artificial neural network. i don't understand how is implemented a 'node' with an electronic circuit
