How are these springed ball connectors called? Can not find them without right name.
    $\begingroup$ Pogo Pins si the usual term $\endgroup$ Feb 20, 2017 at 20:56
  • $\begingroup$ For future reference, you should probably point to exactly what part of the component you are asking about. $\endgroup$
    – hazzey
    Feb 21, 2017 at 14:42
  • $\begingroup$ I did. I asked about springed ball connectors. $\endgroup$ Feb 21, 2017 at 15:21
Spring pin connector
Spring loaded connector
Spring-loaded connector
Spring loaded pin connector
Magnetic spring connector (obviously only if magnetic)
Google image search "spring pin connector"
Mill-Max spring-loaded connector
I found this link that is from the seller.
It's a 26 pins adapter that they call:
Tool-less LCD/EVF Adapter
I believe this is a unique product to the brand.
  • $\begingroup$ Dear Dat Ha. Thanks for your answer, but I am asking about the connector in the middle of this adapter. $\endgroup$ Feb 21, 2017 at 2:37
