How to finish part (a) and (b) of this dynamics problem?
There are no solution or answer in the book...
My professor say that this problem is very tricky, don't even try by yourself.
Sign up to join this communityHow to finish part (a) and (b) of this dynamics problem?
Starting with equating the total energies at the starting and max velocity point. The energy at the starting point comes from the potential energies of the mass and spring. The energy at the other point also has the kinetic energy component of the mass.
$$ m g (R \tan (\alpha )+R)+\frac{1}{2} k \left(\sqrt{R^2+(R \tan (\alpha )+R)^2}-\ell \right)^2 = \\ m g (R-R \sin (\beta ))+\frac{1}{2} k \left(\sqrt{(R-R \sin (\beta ))^2+(2 R-R \cos (\beta ))^2}-\ell \right)^2+\frac{1}{2}m v^2 $$
($\ell$ is the unstretched spring length)
Now we can solve for $v^2$ (or $v$).
$$ \frac{1}{m}(-4. \sin ^2(\beta )-4. \cos ^2(\beta )+16. \cos (\beta )+40. \sqrt{-0.08 \sin (\beta )-0.16 \cos (\beta )+0.24}+(3.92 m+8.) \sin (\beta )-12 +\\ 4. \tan ^2(\alpha )-40. \sqrt{0.04 \tan ^2(\alpha )+0.08 \tan (\alpha )+0.08}+8. \tan (\alpha )+3.92 m \tan (\alpha )) $$
Looking at this expression we see that part of it depends on $\beta$ and the other part on $\alpha$, and there are no cross variables. The other variable is the mass $m$. Given the information that the max velocity is at $\beta=34 {}^{\circ}$, we can equate the derivative of $v^2$ to 0 and solve for $m$. This gives $m = 0.143 kg$.
I think this is as far as we can get with the information provided. The actual velocity is a function of $\alpha$ and as expected higher values produce larger velocities.
$$ 2.64447 \sqrt{4. \tan ^2(\alpha )-40. \sqrt{0.04 \tan ^2(\alpha )+0.08 \tan (\alpha )+0.08}+8.56054 \tan (\alpha )+12.0611} $$
[Update] If $\alpha=45{}^{\circ}$ then the velocity is $6.86192\ m/s$.
(All the computations were done in Mathematica and I am attaching the screenshot).
