I would like to start by stating that my answer is not exactly the same as the one you've found in the literature. It is almost the same, but one sign is switched. I don't know if you wrote it wrong or if I messed up somewhere (very possible, please correct me if you find my mistake). Regardless, I am so close that I'm sure the mistake is somewhere on this page (and not in the literature, of course). And it is close enough to show you where that equation comes from, which is your actual question.
It is worth noting a key difference between the small and big bodies: the big body is in uniaxial tension, but the small one is under biaxial stress. It is under tension in the x axis but under compression in the y axis. Now, the deformation equations for biaxial stress are:
$$\begin{align}
\epsilon_x &= \dfrac{1}{E}(\sigma_x - \nu\sigma_y) \\
\epsilon_y &= \dfrac{1}{E}(-\nu\sigma_x + \sigma_y) \\
\epsilon_z &= \dfrac{-\nu}{E}(\sigma_x + \sigma_y) \\
\end{align}$$
Your small body is under known $\epsilon_x$ and $\epsilon_y$ (equal to those of the big body). From that we can calculate $\sigma_{x,s}$ and $\sigma_{y,s}$. (All variables with index $s$ are for the small body, $b$ for the big body)
$$\begin{align}
\epsilon_{x,s} = \epsilon_{x,b} &= \dfrac{1}{E_s}(\sigma_{x,s} - \nu_s\sigma_{y,s}) \\
\dfrac{\sigma_{x,b}}{E_b} &= \dfrac{1}{E_s}(\sigma_{x,s} - \nu_s\sigma_{y,s}) \\
\therefore \sigma_{x,s} &= \dfrac{E_s\sigma_{x,b}}{E_b} + \nu_s\sigma_{y,s}\\
\epsilon_{y,s} = \epsilon_{y,b} &= \dfrac{1}{E_s}(-\nu_s\sigma_{x,s} + \sigma_{y,s}) \\
\dfrac{\nu_b\sigma_{x,b}}{E_b} &= \dfrac{1}{E_s}(-\nu_s\sigma_{x,s} + \sigma_{y,s}) \\
\therefore \sigma_{y,s} &= \dfrac{E_s\nu_b\sigma_{x,b}}{E_b} + \nu_s\sigma_{x,s} \\
\therefore \sigma_{x,s} &= \dfrac{E_s\sigma_{x,b}}{E_b} + \nu_s\left(\dfrac{E_s\nu_b\sigma_{x,b}}{E_b} + \nu_s\sigma_{x,s}\right) \\
\sigma_{x,s} &= \dfrac{E_s\sigma_{x,b}}{E_b}\cdot\dfrac{1 + \nu_s\nu_b}{1-\nu_s^2} \\
\therefore \sigma_{y,s} &= \dfrac{E_s\nu_b\sigma_{x,b}}{E_b} + \nu_s\left(\dfrac{E_s\sigma_{x,b}}{E_b}\cdot\dfrac{1 + \nu_s\nu_b}{1-\nu_s^2}\right) \\
\sigma_{y,s} &= \dfrac{E_s\sigma_{x,b}}{E_b}\left(\nu_b + \nu_s\dfrac{1 + \nu_s\nu_b}{1-\nu_s^2}\right)
\end{align}$$
Now we just plug these in the $\epsilon_z$ equation. There's a lot to simplify here, so I'll show each of the steps.
$$\begin{align}
\epsilon_z &= -\dfrac{\nu_s}{E_s}\left(\dfrac{E_s\sigma_{x,b}}{E_b}\cdot\dfrac{1 + \nu_s\nu_b}{1-\nu_s^2} + \dfrac{E_s\sigma_{x,b}}{E_b}\left(\nu_b + \nu_s\dfrac{1 + \nu_s\nu_b}{1-\nu_s^2}\right)\right) \\
\epsilon_z &= -\nu_s\left(\dfrac{\sigma_{x,b}}{E_b}\cdot\dfrac{1 + \nu_s\nu_b}{1-\nu_s^2} + \dfrac{\sigma_{x,b}}{E_b}\left(\nu_b + \nu_s\dfrac{1 + \nu_s\nu_b}{1-\nu_s^2}\right)\right) \\
\epsilon_z &= -\dfrac{\nu_s\sigma_{x,b}}{E_b}\left(\dfrac{1 + \nu_s\nu_b}{1-\nu_s^2} + \nu_b + \nu_s\dfrac{1 + \nu_s\nu_b}{1-\nu_s^2}\right) \\
\epsilon_z &= -\dfrac{\nu_s\sigma_{x,b}}{E_b}\left(\dfrac{1 + \nu_s\nu_b}{1-\nu_s^2}(1+\nu_s) + \nu_b\right) \\
\epsilon_z &= -\dfrac{\nu_s\sigma_{x,b}}{E_b}\left(\dfrac{1 + \nu_s\nu_b}{1-\nu_s} + \nu_b\right) \\
\epsilon_z &= -\dfrac{\nu_s\sigma_{x,b}}{E_b}\left(\dfrac{1 + \nu_s\nu_b}{1-\nu_s} + \dfrac{(1-\nu_s)\nu_b}{1-\nu_s}\right) \\
\epsilon_z &= -\dfrac{\nu_s\sigma_{x,b}}{E_b}\left(\dfrac{1 + \nu_s\nu_b + \nu_b-\nu_s\nu_b}{1-\nu_s}\right) \\
\epsilon_z &= -\dfrac{\nu_s\sigma_{x,b}}{E_b}\cdot\dfrac{1 + \nu_b}{1-\nu_s} \\
\end{align}$$
This is almost identical to the equation you've given from the literature, with the exception that my equation has $1 + \nu_b$, while the literature has $1 - \nu_b$. I can't figure out where I went wrong (or if you wrote it wrong), but this is so close that I believe it should demonstrate where the literature got this equation from.
