A sawblade cuts a piece of steel which has a rectangular profile with height $h$ and width $b$. The length of this piece is given by $\ell$ (not relevant for the cutting process). I have a sawblade with length $L$ and sawtooths that have length $\Delta L$ (the sawblade therefore has $N = \frac{L}{\Delta L}$ sawtooths), peak height $f$ (the distance from minimum to maximum of a sawtooth) and thickness of the sawblate is $t$.
The sawblade is attached to the piece of metal with force $F$ and uses full length for sawing (velocity: $v$). A periodic motion front - back - front - back - ... is exerted by the sawblade.
Question 1: Which material parameters of the steel and blade determine how much the saw will penetrate through the piece of metal during ONE saw motion with full length?
Question 2: How long will it take until the piece of metal is cut?
Are there formulas to compute such things?
