Can a signal below -176 dbm, which is 1.6 db below thermal noise at room temperature, be decoded irrespective of the modulation type?
No, not irrespective of modulation type. If you know that you need to deal with signals like that, you pick a modulation scheme that provides "gain" in the demodulation process.
For example, GPS uses direct-sequence spread spectrum, which allows the wideband energy of the signal to be "refocused" to a narrow bandwidth, providing a huge amount of gain over the thermal noise.
