Suppose I have a liquid in a container, the type of liquid is such that it expands when its temperature rises. The contrainer is marked with scale to measure the height of liquid expanded. There is a controller that maintains the temprature at it desired value. Temprature sensor feedback the temprature value to generate error signal into the controller. But the main purpose of the system is to maintain the height which does not have any feedback sensor. The only way to find out is through scale reading which is done by human observer. To maintain the height, the observer changes set point temprature. So first, what is the actual name of this kind of system, an open loop system for height control? Second is this block diagram correct in control theory?
Control sytem
  • $\begingroup$ It's a closed loop system, since temperature is feed back and compared to a set-point temperature. $\endgroup$
    – jjack
    Nov 25, 2016 at 15:19
This system can be considered "closed loop," since the control input is being determined by some sort of feedback loop (even though the mathematical expression of the feedback loop through the operator is unknown). Also, yes the diagram you've shown is valid. I often work with control systems that have a human operator in the control loop, such as robotic teleoperation systems, and they are often shown as some black box operating on a feedback signal.
However, it would be difficult to apply any sort of control theory to your system without some sort of model of how the human operator reacts to the height of the liquid. Often you can make an assumption, like maybe the operator behaves like a proportional controller with a bit of noise (you would need to have solid justifications for any assumptions you make). Either way, in this case if you want to control the height of the fluid with any amount of precision, replace that operator with an ultrasonic rangefinder (or some other sensor) plus some variation on a PID controller.
  • $\begingroup$ Thanks. But i have a little confusion, is there any other scientific name for this kind of system in which human operator controls a variable by varying other variable? Thanks $\endgroup$
    – Taha
    Nov 25, 2016 at 17:31
  • $\begingroup$ @Taha I would say the human operator changes the reference input of the control system. $\endgroup$ Nov 25, 2016 at 17:35
  • $\begingroup$ @Taha you can go with Mirko 's suggestion, however for the purposes of control theory the operator is just another function operating on the feedback signal. You can call the operator output the 'reference trajectory', but the system is still a closed loop system. The human operator closes the loop, behaving as an unknown control action. Is the loop closed as far as the math is concerned? Yes. Is this a good control setup? Not really. If you want to make it clear that a human provides the main control input, just say that the height is operator-controlled or human controlled. $\endgroup$ Nov 25, 2016 at 18:21
