I have encountered some issues with sketching the nyquist plot for the following loop transfer function:
$L(s) = \frac{25K}{S^2+25}$
I know that you first take:
$L(\omega=0) = K$
$L(\omega = infinity) = |0| e^{-180}$
For the larger part of the D contour, as for the smaller section of the D counter, I sub $\omega = \epsilon e^{\gamma}$ to represent a number with small magnitude and phase, if I substitute that into the transfer function, that is $L(\epsilon e^{\gamma}) = \frac{25K}{25} = K$ as $\epsilon e^{\gamma} + 25 \approx 25 $
From this information I can do a rough sketch of the nyquist plot, but when I plot it out on matlab I get something very different. Is my thought process on this correct?
