This question is going to have an application in aviation (to avoid doubts and relocation to other forum) but let's concentrate on theoretical mechanics here.
If I want to allow a shaft to rotate in one direction and not the other, then a ratchet would be a solution.
But what I need is a base/platform with shaft M (master) and shaft S (slave) connected to each other the way that if I rotate shaft M (both clockwise or counter-clockwise) the shaft S will rotate with the same speed and direction. But if I try to rotate shaft S in any direction it should not be possible the same way as if I tried to rotate a ratchet in blocked direction.
What is the name of a device I described?
Shaft M --> ===[Device in]=== <-- Shaft S
_______________[question ]________ <-- platform
