I believed that the flame propagates over the place where fuel contacts the oxygen. If it contacts a fule+O2 mixture, the mixture inflames as well, and so on and on and on until there is no more inflammable material available around. If there is a gas comes to the surface, the flame stops and starts burning at the gas-air contact zone.
But, as it was explained yesterday, I can have the gas burning in my gas baking chamber because it gets mixed with air prior to getting into the chamber. This explain the mystery of having the flame in a sort of isolated chamber, but, what they refused to explain is that how it is possible that mixture does not blow up in the pipe as soon as you mix gas + air? Why don't you have the flame there, how do you prevent the mixture ignition until after it crosses the designed burner? How does the gas know how the burner/nozzle look like in order to inflame in the right place? My belief was that flame propagates in all directions over the fuel+oxygen mixture, so, it should propagate from the burner down the pipe until the gas-air mixer, right?
BTW, is it right that a hole in a gas pipe sucks the air despite gas in the pipe has pressure > 1 atm (it must be greater than 1 atm in order to be pushed out of the gas pipe instead of sucking the air into it)? How is it possible that gas flows from lower pressuire into the higher pressure area without violation of entropy principle?
I have noticed that there is a similar question on Quora. It is even more infomred than mine assumption -- it asks why no flahback arrestors are installed in the kitchen ovens? There should be absolutely no chance for the flame to go upstream over the explosive mixture! Why?
I keep asking my question because highly appreciated answer there is unsatisfactory. It just says that we use propane cooking cylinders
in our kitchens. These cillinders have much higher pressure than the air oxygen, and, therefore, backpropagation is not possible, says the answer.
However, it prevents the backward propagation of GAS whereas safety issue is propagation of flame. how does it make the flame speed necessarily lower than the gas flow speed, what happens on the last days of cylinder exhaustion when pressure goes down and what about the centralized (natural) gas kitchens?
  • $\begingroup$ Great Question and welcome to Engineering Stack Exchange! I was always told in welding class that a flash arrestor (en.wikipedia.org/wiki/Flashback_arrestor) was used in front of the torch so if the flame goes backwards, it gets stopped at the valve. So, your question has merit. But someone else probably has a better explanation for more complex situations. $\endgroup$
    – Mark
    Commented Nov 7, 2016 at 22:12
  • $\begingroup$ @Mark As I understand, the flashback arrestor saves you in emergency case. I am asking why it is normally not used/unnecessary, why does the flame does not propagate backwards itself under normal conditions and what is necessary to have in mind in order to maintain those conditions? $\endgroup$ Commented Nov 8, 2016 at 6:30
  • $\begingroup$ @Mark A similar question in Quora even assumes that we do not need the flashback arrestors on the kitchen and they are not used there! So, there is something else that prevents the flame backward propagation over the explosive mixture. $\endgroup$ Commented Nov 8, 2016 at 6:48
3 Answers 3
Depending on fuel, a flame has a certain propagation speed - the speed with which the flame wanders through the medium. If the fuel - oxygen mixture moves faster through the pipe than the propagation speed of the flame, the flame can't 'walk'back. Like trying to run on a threadmill that's to fast.
The speed of the fuel-air mixture depends on the area of the pipe, the pressure and the mass flow. The smaller the pipe, the higher the speed. Once the mixture leaves the pipe it will slow down. Look at the picture of a burning oil well a bit down on the linked page: If you look carefully, you will see a cone shaped area between the end of the pipe and the flame. This is the spray of oild widening after leaving the pipe, slowing down. The flame starts where the speed of flame propagation is the same as the speed of the oil spray. Of course, a pre-mixed flame would have a higher flame propagation speed than a diffusion flame.
Here's a little graph of flame propagation speeds for pre-mixed stochiometric propane-air mixtures:
Image source: Vorlesungsskript Technische Verbrennung, N. Peters
The temperature refers to the unburnt part. As you see with higher temperatures the flame propagation is much faster.
Note that when the pressure in the bottle falls, the speed of fuel will fall also and it can become possible for the flame to 'walk' back to the bottle - so you should always have a properly designed system with a flame arrestor and if you have to ask you can't design it yourself.
You also asked how high pressure gas can 'suck' air through a whole. That's the venturi effect, fast flowing fluids have lower pressure. In all gas burners that used this for mixing in air I have seen, the mixing was after the pressure regulator where the gas is close to atmospheric pressure allready.
  • $\begingroup$ I actually wanted to hear the rought numbers of the pipeline/bottle gas mixture vs flame speeds, how they are related to the pressure and what, for instance, makes the Meker-Fisher_burner absolutely safe. But, your fundamental principles are utterly illuminating. $\endgroup$ Commented Nov 8, 2016 at 8:51
  • $\begingroup$ Strictly speaking, that's the edge of the oxidation reaction, not the visible"flame", right? $\endgroup$ Commented Nov 8, 2016 at 14:29
No fuel (in the conventional sense) will burn without being mixed with oxygen. However it is entirely possible for air to get mixed with fuel in unexpected ways, especially if you have leaks in the system.
In this context is is important to remember that gas pressure measured at a regulator is static pressure but if you use that pressure to move it through a pipe and nozzle it is subject to the bernoulli principal
Also very relevant is the venturi effect, indeed gas burners without forced air induction rely on this to work. Here the high pressure gas flow is accelerated through a small nozzle whcih casues a pressure drop thus sucking in air through holes in the back of the burner.
Yet another complication is that if you have a flame in a contained space the convection caused by heating can cause upredicatable pressure fluctuations and even further variations in combustion rate can cause rapid ignition of unburned gas reaulting in shockwaves which can propogate back into the gas line potentially sucking in air further compicated by the fact that transsonic shickwves follow entirely differnt rules.
Tyhe short answer is that this is why we have flashback arrestors.
    $\begingroup$ I did read the whole Bernoulli article but did not find anything related. What do you mean? Do not throw keywords. Explain how they are related to the matter of flame propagation in our case. $\endgroup$ Commented Nov 7, 2016 at 19:00
  • $\begingroup$ The important thing is that gas flow at a nominal static pressure can, if it is flowing with some velocity have a net negative pressure compared to the atmosphere. To put in another way pressurised gas flow can exert a suction force. $\endgroup$ Commented Nov 7, 2016 at 19:03
  • $\begingroup$ Ok, this is related to the secondary question. Let's make the major question clear first. How does bernoulli prevent the flame backward propagation? I know that bernoulli may explain a lot of things. But, just spelling the name of a principle does not explain anything to the uninitiated. Read the article yourself: there is a 100-year old debate if bernoulli explains the lifting power or not. So, if you say that it explains, you should explain how. Saying just static pressure is not enough. This does not tell anything to me. $\endgroup$ Commented Nov 7, 2016 at 19:37
  • $\begingroup$ One approach - I suppose it's a crude form of flashback suppressor - is a wire mesh downstream of the nozzle and venturi, and the flame downstream of that. Such as en.wikipedia.org/wiki/Meker-Fisher_burner . The mesh has to be reasonably coarse, so as not to impede the flow through the venturi. $\endgroup$ Commented Nov 7, 2016 at 22:59
I keep asking my question because highly appreciated answer there is unsatisfactory. It just says that we use propane cooking cylinders in our kitchens. These cillinders have much higher pressure than the air oxygen, and, therefore, backpropagation is not possible, says the answer.
I think this part of question is not addressed, so I'll give it a try.
Kitchen ovens are supplied with only one gas source (butane cylinder in my case). While pressure in cylinder is greater than atmospheric pressure there can be no flashback because cylinder and lines which supply it to the oven are filled only with butane. And they are filled only with butane as long as pressure in the cylinder is greater than atmospheric. Since there is no combustible mixture ignition is not possible there, nor is flame able to propagate. So there is no danger of flashback/explosion.
Once cylinder/line pressure drops close to atmospheric gas flow will be too weak to sustain flame on the exit line (partly explained in mart's answer), so you'll be forced to replace the cylinder far before air gets inside. And even if air somehow gets inside and mix properly (which is not likely because butane is heavier than air, so it will always remain at the bottom of the cylinder) I don't think there would be enough energy released to cause cylinder to explode.
Where I'm from there was always warning not to turn the cylinder upside down when depleted, because then remaining butane could escape and make room for air.
