I'm trying to simulate a compound action potential for calibrating research instruments. The image below is a small overview of the design.
I've already completed the data acquisition from a live animal, and processed the data in MATLAB to make a nice, noise-less signal, with 789 values in 12-bit format. I then cloned the repository to the Pi using Git. Below is the Python script I've written on the RPi. You can skip to def main in the script to see functionality.
#!/usr/bin/python
import spidev
from time import sleep
import RPi.GPIO as GPIO
import csv
import sys
import math
DEBUG = False
spi_max_speed = 20 * 1000000
V_Ref = 5000
Resolution = 2**12
CE = 0
spi = spidev.SpiDev()
spi.open(0,CE)
spi.max_speed_hz = spi_max_speed
LDAQ = 22
GPIO.setmode(GPIO.BOARD)
GPIO.setup(LDAQ, GPIO.OUT)
GPIO.output(LDAQ,GPIO.LOW)
def setOutput(val):
lowByte = val & 0b11111111 #Make bytes using MCP4921 data sheet info
highByte = ((val >> 8) & 0xff) | 0b0 << 7 | 0b0 << 6 | 0b1 << 5 | 0b1 << 4
if DEBUG :
print("Highbyte = {0:8b}".format(highByte))
print("Lowbyte = {0:8b}".format(lowByte))
spi.xfer2([highByte, lowByte])
def main():
with open('signal12bit.csv') as signal:
signal_length = float(raw_input("Please input signal length in ms: "))
delay = float(raw_input("Please input delay after signal in ms: "))
amplitude = float(raw_input("Please input signal amplitude in mV: "))
print "Starting Simulant with signal length %.1f ms, delay %.1f ms and amplitude %.1f mV." % (signal_length, delay, amplitude)
if not DEBUG : print "Press ctrl+c to close."
sleep (1) #Wait a sec before starting
read = csv.reader(signal, delimiter=' ', quotechar='|')
try:
while(True):
signal.seek(0)
for row in read: #Loop csv file rows
if DEBUG : print ', '.join(row)
setOutput(int(row)/int((V_Ref/amplitude))) #Adjust amplitude, not super necessary to do in software
sleep (signal_length/(data_points*1000) #Divide by 1000 to make into ms, divide by length of data
sleep (delay/1000)
except (KeyboardInterrupt, Exception) as e:
print(e)
print "Closing SPI channel"
setOutput(0)
GPIO.cleanup()
spi.close()
if __name__ == '__main__':
main()
This script almost works as intended. Connecting the output pin of the MCP4921 to an oscilloscope shows that it reproduces the signal very well, and it outputs the subsequent delay correctly.
Unfortunately, the data points are seperated much further than I need them to be. The shortest time I can cram the signal into is about 79 ms. This is due to dividing by 789000 in the sleep function, which I know is too much to ask from Python and from the Pi, because reading the csv file takes time. However, if I try making an array manually, and putting those values out instead of reading the csv file, I can achieve a frequency over 6 kHz with no loss.
My question is this
How can I get this signal to appear at a frequency of 250 Hz, and decrease it reliably from the user's input? I've thought about manually writing the 789 values into an array in the script, and then changing the SPI speed to whatever value fits with 250 Hz. This would eliminate the slow csv reader function, but then you can't reduce the frequency from user input. In any case, eliminating the need for csv.read would help a lot. Thanks!
