I have an engineering application where I would like to use a single 24v DC Stepping Motor to power two different axles of opposing direction. Basically when the motor turns clockwise, Axel A will spin and Axel B will be stationary. When the motor turns counter-clockwise, Axel A will be stationary and Axel B will spin.
I need it to be as cheap and simple as possible. So far, the best solution that I could come up with to accomplish this is by using two gears similar to the bicycle Freewheel / Freehub. The problem is, I cannot for the life of me find a gear that is similar to that application, but for uses outside of bicycles (possibly because I don't know that specific gear's name). Can anyone recommend a gear or something that is similar to the application that I need?
I have a general idea of the function that I need, but I don't know the name of this type of ratcheting gear.
