I am trying to derive the isentropic flow equations for a compressible gas by myself and at the end, I have different formulation than the one in the literature. Can you please tell me what am I doing wrong?
So we have a nozzle:
If we do an energy balance and consider that the kinetic energy and the potential energy in point 1 is negligible, one ends up with this relation: $h_1=h_2+\dfrac{v_2^2}{2}$
By using the ideal gas relation $h = CpT$, and if we then divide the equation by Cp and then by $T_2$, we end up with something like this:
$\dfrac{T_1}{T_2}=1 + \dfrac{v_2^2}{2T_2Cp}$
And finally using $Cp = Cv + R$, denoting $Cp/Cv = k$, using the formula for the mach number $M = v/c$ and the speed of sound in gas $c = \sqrt{(T_2Rk)}$, we end up with this relation:
$\dfrac{T_1}{T_2}=1 + \dfrac{k-1}{2}M^2$
But from the literature one can find that this formula is written like this:
$\dfrac{T_t}{T}=1 + \dfrac{k-1}{2}M^2$
The question is... Is the total temperature $T_t$ in their equation the same as $T_1$ in our case? And if the nozzle discharges to the ambient, is $T$ in their formulation the same as $T_2$ in ours? I'm a bit confused with the symbols and the meanings and I want to learn how this works.
P.S. This is a copy of a question from enter link description here. I have been suggested to try and ask here.
$T_t$ is called the stagnation temperature, which is the temperature of a flow when it's brought to rest ($v=0$), the $T_1$ you defined in the first equation is called the stagnation temperature since you ignored kinetic energy.
$$C_pT_t = C_pT + \frac{v^2}{2}$$ $$T_t = T + \frac{v^2}{2C_p}$$
Yes, the arbitary $T$ in the equation is for any location in the nozzle including the discharge.
  • $\begingroup$ Thank you very much for your answer. I have one more question. If one would put a thermocouple in point 1, which temperature would it read? This is what confuses me when dealing with stagnation points. $\endgroup$
    – Physther
    Oct 18, 2016 at 7:48
  • $\begingroup$ @Paul Theoretically, you'd be measuring stagnation temperature, since the flow is at rest. $\endgroup$
    – Algo
    Oct 19, 2016 at 3:41
