I have the formula for the translational stiffness which is :
However, what I would like to find is the rotational stiffness. Is there any formulas to convert from one to an other knowing the pitch of the screw and the diameter ?
The translational stiffness is written as $$ k_l = \frac{A\,E}{\ell},$$ where the stiffness $k_l$ is in $\left[\frac{N}{m}\right]$, the area $A$ is in $\left[m^2\right]$, the young's modulus is in $\left[\frac{N}{m^2}\right]$ and the length $\ell$ is in $\left[m\right]$.
The rotational stiffness is written as $$ k_r = \frac{G\,J}{\ell},$$ where the stiffness $k_r$ is in $\left[\frac{Nm}{rad}\right]$, the second moment of area (or torsion constant) $J$ is in $\left[m^4\right]$, the rigidity modulus is in $\left[\frac{N}{m^2}\right]$ and the length $\ell$ is in $\left[m\right]$.
Assuming linear elasticity the following relation between the rigidity modulus and the young modulus holds $$ G = \frac{E}{2(1+v)},$$ where $v$ is the poison ratio.
The second moment of area (or torsion constant) for a circle is $$ \iint\limits_{R} r^2\,dA = \int_0^{2\pi}\int_0^r r^2\left(r\,dr\,d\theta\right) = \int_0^{2\pi}\int_0^r r^3\,dr\,d\theta = \int_0^{2\pi} \frac{r^4}{4}\,d\theta = \frac{\pi}{2}r^4 = \frac{A\,r^2}{2}. $$
Hence the rotational stiffness of a cylinder can be rewritten as function of $k_l$ $$ k_r = \frac{\frac{E}{2(1+v)} \frac{A\,r^2}{2}}{\ell} = \frac{A\,E}{\ell} \frac{r^2}{4(1+v)} = k_l \, \frac{r^2}{4(1+v)} $$
This equation does not hold for any other shape!
When looking at a screw, there is a thread at the outside which has a significant effect on the rotational stiffness.
For example, leaving half the diameter open in the cylinder, the stiffness will only decrease $0.0625\%$ which is insignificant. Increasing the outer radius will increase the stiffness significant.
11
  • $\begingroup$ The formula is how to calculate the rotational stiffness from the screw parameters. But what I'm trying to do is convert the translational stiffness into rotational stiffness. Without knowing G or J. $\endgroup$ – Crapsy Oct 5 '16 at 20:21
  • $\begingroup$ I improved my answer. Is this what you meant? $\endgroup$ – useless-machine Oct 5 '16 at 21:23
  • $\begingroup$ There is not any correlation between axial stiffness in a prismatic section and torque or rotational stiffness. J which is mass moment of inertia of the section is dependent on the cross section of the piece and weather it is hollow or solid! $\endgroup$ – kamran Oct 5 '16 at 21:27
  • $\begingroup$ @kamran there is a correlation between them since I assumed linear elasticity and that the cylinder is solid. $\endgroup$ – useless-machine Oct 5 '16 at 21:44
  • $\begingroup$ What if the bar is shaped like an "H" or anything other than a cylinder? The OP has not restricted the cross-section to cylinder. $\endgroup$ – kamran Oct 5 '16 at 22:10
