I work as a research assistant in the field of water resources management. We build small scale physical models of rivers and make experiments with sediment. The model rivers are about 20m long and 3m wide, the water depth is from 0 to half a meter. The bottom is either concrete or gravel.
One important task is to quantitatively measure the bedform that results after a model run. (i.e. where the gravel got washed away and where it accumulated)
I was wondering whether there is a chance to use a medical ultrasound device to record the topography of the (river) bottom. I'm hoping that these devices deliver a 2D profile of the riverbed and if I track to position + orientation of the ultrasound probe I can put together a 3d topography.
Has anyone ever done some experiments like that? I mean alienated a ultrasound device? or can anyone tell me why my idea is theoretically bad / good? Where could be problems? Is it possible to get spatial information out of an ultrasound image? I mean in the image the ground should become apparent very clear as there is only water between the sensor and the ground. I'm aiming at an accuracy of the resulting topography of about 5mm.
9
    $\begingroup$ If you're looking for the surface composition an ultrasound isn't really what you're looking for, look more for lidar and depth imaging cameras. $\endgroup$ Commented Sep 15, 2016 at 12:54
  • $\begingroup$ the composition is not what we want - just the "first echo" or surface of the riverbed. Lidar or photogrammetry wont work in turbid water - unfortunately the water is often turbid... $\endgroup$
    – Mathias
    Commented Sep 15, 2016 at 14:27
    $\begingroup$ I'd think you'd be looking for some kind of sonar like a fish finder rather than a medical device. Medical devices are expensive, in large part because they're regulated so tightly. $\endgroup$
    – DLS3141
    Commented Sep 15, 2016 at 16:51
  • $\begingroup$ Fish finders also function in turbid water $\endgroup$
    – DLS3141
    Commented Sep 15, 2016 at 20:16
  • $\begingroup$ Thank you for yor answers! Fishfinders like from Lowrance or Humminbird have the downside that they only work in water depths of more than 0.5m. I've already tried a Lowrance device. As our model rivers are mostly very shallow ( few centimeters to maximum half a meter) these devices are ruled out. Also the resolution is not sufficiant for our needs. I really want to try a medical ultrasonic system - but wanted to ask if anyone can tell me if I maybe overlook sth and this wont work at all and I only waste time... $\endgroup$
    – Mathias
    Commented Sep 16, 2016 at 7:23
I've had the possibility to test several different diagnostic ultrasound devices in a big bucket of water with gravel at the bottom! The result is interesting: At first, for all devices you have to use a "curved sound head", the linear one doesn't work at distances further than a few centimeters. With cheap devices I could hardly see the bottom or the gravel. With more expensive 3D / 4D devices the bottom and gravel became very clear and with the software we could measure distances with mm accuracy. The problem which however remains, is that the data cannot easily be exported for further processing. And there are to few parameters so adjust (not generally!, there are a lot... but for this special purpose). For example a tested "4D device" records a 3D model of the object when you scan it from different angles (e. g. for getting images of babys in 3D), but the time over which the images are taken is fixed and so the area of the riverbed which could be recorded is limited.
So basically the principle works - you can record the riverbed with mm accuracy but the devices are to much like "black boxes".
  • $\begingroup$ This is an neat bit of experimental research. By any chance, could you post some pictures? $\endgroup$ Commented Mar 6, 2017 at 2:39
