QUESTION
For a business project, I'm looking into the viability of a greenhouse situated in Canada's far northern town of Iqaluit. The problem is how to mathematically simulate the internal air temperature of the greenhouse.
WHAT I ALREADY HAVE
- detailed 3D renderings of the greenhouse
- all materials with their corresponding thermodynamic values such as K-values
- climate data that shows the approximate intensity of solar radiation in Iqaluit, angles of sunlight throughout the day and hourly temperature data.
- data for the required environment for certain crops to thrive, such as humidity, required sunlight, temperature fluctuations, pH, etc.
CONTEXT
What make this greenhouse investigation unique is that the greenhouse is a much smaller affordable design that is meant to grow a small supplementary source of fresh produce for low-income families which often suffer from food insecurity in northern towns such as Iqaluit due to prohibitively high costs for fresh produce.
We would also like to strive for simplistic, mechanical systems that are easier to maintain and less prone to failure. A major concern of the group as of now is by how much could the internal air temperature plummet by at night?
GOAL
The goal in mind is to use the information we have so far to determine:
Is it possible to grow vegetables such as leafy greens within the current design WITHOUT an external power source other than sunlight? (A greenhouse that does not require electric heating is a major goal) How does the internal air temperature vary with the current design?
In the case that the current design is not sufficient for healthy crop growth, what modifications are necessary? (Many potential solutions have been considered):
- Have a solar powered heater that charges through the day and intermittently provides heat through the night.
- Greatly increase thermal insulation surrounding the greenhouse through the use of a thick air-inflated wrap that surrounds the entire structure in addition to thicker polycarbonate panels for construction.
- Use a setup of concave reflective panels surrounding the greenhouse to increase the amount of heat collected during the day. I have already done some calculations but my numbers ended up far off. Equations I have worked with so far are $Q = mc\Delta T$ and $\dfrac{Q}{t} = \dfrac{A\Delta T}{\text{Thermal Heat Transfer Coefficient}}$.
CONCLUSION
I think the problem demands looking at every single material and also examining the characteristics of the air inside as an ideal gas, as well as the poly-carbonate and it's emissivity/albedo (black body) characteristics.
Any steps or hints in the right direction with equations or methods of calculation would be greatly appreciated!
