How do shoreline nuclear facilities lower the temperature of wastewater generated by their cooling systems before it enters the ocean?
    $\begingroup$ Possibly helpful: nrdc.org/sites/default/files/power-plant-cooling-IB.pdf and en.wikipedia.org/wiki/Cooling_tower $\endgroup$ – Carl Witthoft Aug 9 '16 at 14:15
    $\begingroup$ Increase the volume of water through the cooling system and the water temperature rise will be reduced. That's the advantage, I presume, of a seaside site - unlimited water. $\endgroup$ – Transistor Aug 9 '16 at 18:56
    $\begingroup$ Water is not dumped in the ocean during normal operation. The clean cool steam/condensate from the turbines is cooled in the large funnel shaped cooling towers and returned to be reheated in a closed system . The steam coming from the towers is from fresh water sprayed onto the tubes containing the turbine steam/water. Although , I did hear that Russia did have a few reactors that did use "once through" river water for the turbines, but this was stopped years ago. $\endgroup$ – blacksmith37 Jun 30 '18 at 19:01
One way is to use massive pond systems for evaporate cooling.
Turkey Point nuclear plant. Closed loop system explained here - https://youtu.be/qt9dtYC7RDE
| improve this answer | |
In heat exchanger design, typically a maximum rise is specified by the end user - be it the environmental control groups, or the plant designer itself. The heat exchanger is then designed to remove the required amount of heat, which is known, by having the output have a certain temperature fall of the first stream, and a maximum temperature rise. The actual temperatures are then simulated in various selected heat exchangers, until a desired heat exchanger that matches the constraints is determined. Usually this comes with a desired flowrate on both the hot line and the cool line. The cool line flowrate would usually be a minimum to remain open, and conservatively additional flow would be designed into the system (larger pumps, larger pipes, etc).
