If we need to measure the Electrostatic field of a celestial body due to its interaction with space plasmas, What kind of instruments can be used to achieve this?
One way to measure electric fields directly is called a "field mill".
It uses moving vanes to impose an AC modulation on the field and a differential sensing setup that allows most sources of error to be zeroed out, something like how a chopper-stabilized opamp works.
