In order to have continuous service a mobile devices switches to base station with higher signal strength.
Question: Is it possible using the mobile device (Android or iPhone) to determine to LTE base station to which the device has established a connection?
Note: I am interested only for LTE service/devices
You can see this information if you enter "field test mode". Google that for device specific instructions. It should show you the name or serial number of the base station you are connected to, but I'm not sure if you can use that to find it's physical location, although I haven't tried.
