I have a 3 m x 1 m x 1 m cuboid weighing approximately 10,000 kg. I am trying to resolve the vertical forces that will support the cuboid if the cuboid must rest at a 45 degree angle.
Which of the two solutions below (if either) is best for calculating the resolving forces?
In both cases I assume a 2-D cross section of the cuboid where the resolving forces act at the bottom two corners.
The first method is to treat the cuboid as a beam and the weight as an continuously distributed load. This results in an even distribution of the load between the two resolving forces being even irrespective of the angle.
The second method is to assume the weight to be a point load at the center of mass. Then use the sine rule to determine the position the force acts along the base line of the beam. This gives an uneven distribution of the loads with weighting slightly towards the lower corner but seems to be dependent on thickness.
I am reasonably confident it is the second but I want to know the mathematical explanation.
