In Russia, there's a special term for a pipe that is not circular in its section: "a profiled pipe" (профильная труба). There's even a Wikipedia page for it: профильная труба. Such pipes come in a wide variety of sizes and usually have an oval, square or rectangular section ("profile" in Russian), but other kinds of sections are possible.
I wonder what is the common cover-all technical term describing "any kind of non-circular pipe".
Example of usage:
Pervouralsk New Pipe Plant produces a range of non-circular pipes, including pipes of variable cross-section.
(Also asked on ELL SE)
For structural purposes these are usually called Hollow Structural Sections (HSS). For non-structural purposes Mechanical Tubing is often used.
In Europe the main body that deals with structural design of these is CIDECT, who have a series of useful design guides. The equivalent would probably be the Steel Tube Institute in the USA who also deal with non-structural components.
  • $\begingroup$ I'd have gone for simply "Tube" rather than "mechanical tubing". Hollow Structural Section is also a good answer. Which is better depends on the audience. $\endgroup$
    – AndyT
    Jun 13, 2016 at 14:21
