In general, will screws tightened at room temperature become tighter or looser at very low temperature (5 K)?
On the one hand, the screw should loosen because it will contract radially, while the surrounding material will contract slightly less (or even expand, in the limit of a very large screw radius and a very thin ring of surrounding material).
On the other hand, the screw should tighten because the screw should contract linearly along its axis, making the threads tighter, while the surrounding material should contract slightly less because it has other boundary conditions.
Is there a general answer, or does it depend on material, screw size, and/or the exact geometry?
