Engineering Stack Exchange is a question and answer site for professionals and students of engineering. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
  3. The best answers are voted up and rise to the top
When building things like floors to walk on, we use materials like 2"x10" wood joists or steel I-beams. I'm primarily interested in knowing why a 2"x10" piece of wood resists bending downward when you have it "standing up" (ie, the 2" side facing the sky) as opposed to when you have it "laying down" (ie, the 10" side facing the sky).
It seems intuitive to me based on experience, but I can't actually explain why we orient floor joists the way we do even though it seems obvious that will lead to a stronger floor. I imagine whatever the reason is, it also explains why I-beams have such a thin webbing between the two sides.
share|improve this question
up vote 7 down vote accepted
Get a gallon of milk, and shake it up and down by moving your wrist only.
Then, hold your forearm out and shake it by moving your elbow only.
Then, hold your entire arm out and shake it by moving your shoulder only.
The mass didn't change, but the force it took to move it goes up (a lot!) because it is farther from you. This phenomenon, when referring to rotating a mass (as in rotating about your wrist, elbow, or shoulder) is called the "moment of inertia" or, specifically, the "mass moment of inertia."
Similarly, it becomes "harder" to apply the same force to anything the farther from the force origin you get. In instances other than mass specifically, as in I-beams or wood beams, the property of interest is called the "area moment of inertia" or, to add to the confusion, also the "second moment of area."
Essentially, the more material (cross-sectional area) you can put away from the force, the less of an impact that force has on the material. It's very similar to how your shoulder has to work so hard to shake the milk.
You could also consider that, for a given arc of motion, the material spanned by that arc increases linearly with distance, and so you could also consider that your force is getting applied to more material (though this isn't quite technically correct), and because it's getting applied to more material the effective force is diminished.
:EDIT:
I made a picture (not animated, sorry) that shows a traversed arc, and how it remains constant if the traversed angle decreases linearly with increasing distance.
The point of this graphic is to demonstrate strain. If your shoulder did the same work as your wrist, then the gallon of milk would go up and down the same linear distance, but it would not traverse the same angle.
Bending and Deflection
Similarly, if you attempt to bend something, as in a floor joist, the change in length (strain) in the material may be the same, but if you can put the material farther from the bend axis then that strain corresponds to a smaller deflection.
Let's try a numeric example. Consider a very short, very wide rectangular beam whose cross-sectional width is 10m and cross-sectional height is 0.1m. This beam is representative of a slice, but I'm using it for this example to hopefully drive the point across.
The area moment of inertia of the beam about its x-axis ($I_x$) is given by:
$$ I_x = \frac{bh^3}{12} \\ I_x = \frac{(10)(0.1^3)}{12}\\ I_x = 0.000833 \\ $$
The area moment of inertia for the beam is very small about the x-axis - it is very easy to "twist" about the x-axis.
Now, using the parallel axis theorem, let's set that up at a distance of 1m from the bending axis. This means that the area moment of inertia about the bending axis is:
$$ I_x = I_{x'} + Ad_y^2 \\ I_x = 0.000833 + (1)(1^2) \\ I_x = 1.000833\\ $$
So you can see, the area moment of inertia for bending is about 1 for this example, where the distance of the beam from the bending axis is 1. Now, if the beam is moved out to a distance of 2m from the bending axis, the parallel axis theorem gives the new area moment of inertia to be:
$$ I_x = I_{x'} + Ad_y^2 \\ I_x = 0.000833 + (1)(2^2) \\ I_x = 4.000833 \\ $$
So, when the distance is doubled, the area moment of inertia approximately quadruples. Now, consider the bending stress:
$$ \sigma = \frac{My}{I} \\ $$
The bending moment, times the distance from the bending axis, divided by the area moment of inertia. Now, for the first example, the beam was at 1m, and the area moment of inertia was approximately 1. This means that the stress works out to approximately $\sigma = \frac{M(1)}{(1)}$, or $M$.
When the beam is moved out to 2m, the moment of inertia became approximately 4, but now the distance $y$ to get to that beam is $2$, so the bending stress becomes approximately $\sigma = \frac{M(2)}{4}$, or $\frac{1}{2}M$. Putting the beam out at twice the distance caused the bending stress to halve. Strain is linearly related to stress by Young's modulus (assuming elastic deformation), so this means that the strain, or elongation, is also halved by moving the beam twice as far.
Again, this was an illustrative example where I picked the beam size to drive the area moment of inertia of the beam itself to a negligible value such that the parallel axis theorem was the dominating factor. This was done to reinforce the concept that material placed farther from the bending axis results in less stress (and thus less deformation/bending) at the edge of the material.
share|improve this answer
thank you for the explanation, but im also curious if you would be able to explain through pictures and no symbols that "it becomes "harder" to apply the same force to anything the farther from the force origin you get."? or, is this just one of those things we've observed and can describe really well, but seems to just be a "way things work in this universe"? for example, you might be able to explain using visuals only why a temperature increase could also increase the pressure inside the container, but is there an equivalent for this? thanks!! – tau Jan 29 at 1:53
Frankly I don't agree that this answers the question correctly. All you've done is discuss bending stress as a function of beam length. The OP wants to know how a beam of rectangular cross section handles that stress as a function of orientation. – Carl Witthoft Jan 29 at 13:36
@CarlWitthoft: "the more material you can put away from the force, the less of an impact that force has on the material" is correct, but the rest of it seems a bit off the mark. I agree that the moment of inertia stuff had me thinking "ok, this is similar, but slightly different from the real answer". I think it's enough to get someone thinking in the right direction, about leverage, though. – Peter Cordes Jan 29 at 13:40
@CarlWitthoft - I'm not sure what you're saying. Changing the orientation of a rectangular beam changes the distance from the bending axis to the edge of the beam. This changes the bending stress, which changes the deflection. I'm updating my answer now; hopefully it will make things clearer. – Chuck Jan 29 at 14:15
The web or wide part of the 2x10 is the part that resists bending. A wider 2x? or web will resist bending under heavier loads. The force being transferred through the web means that more material needs to stretch or compress for it to fail.
Imagine bending a 2x10 in plane with the 10 inch part. The bottom part will be stretching along the length of the joist and the top will be compressing. Having more material to resist those forces makes a stronger joist (or I-beam). Using a 2x10 with the web face-up would have very little material resisting the stretching or compressing which would lead to failure much more easily.
i have thought that, but isnt there the same amount of material to stretch with the web face up? ie, what is the difference between 10" face up vs 10" in plane? this is where i get stuck. – tau Jan 28 at 19:44
I think this is the best answer so far. It's like showing you can easily fold a sheet of paper the "usual" way, but just try folding it in its own plane! – Carl Witthoft Jan 29 at 13:34
In the context of engineering calculations this is down to a property called 'second moment of area', the way that this is defined is a bit obtuse but is describing something which is reasonably intuitive.
If you consider a joist, supported at both ends with a weight at a point in the middle it will (obviously) bend. This bending force is trying to stretch the bottom edge and compress the top edge so logically there is a line along the middle where it is neither bending nor compressing and similarly the greatest stress is at the top and bottom edge, decreasing towards the middle.
If you do the full analysis it turns out that the stiffness of the beam is directly proportional to its width but also to the cube of it's depth.
So, in terms of bending the distance between centreline and edge of a beam (in the direction of load) is much more important than just its cross-sectional area.
By extension the material near the centreline is contributing much less to the stiffness than material near the edge and something like an I-beam is just a way of dispensing with much of this material which is adding mass but not contributing much to stiffness.
please correct me if im misunderstanding: the width (2", in the case of a 2"x10" joist) increases the stiffness linearly and the depth (10" ^ 3, in the case of a 2"x10" joist) increases stiffness by the cube of the depth? is there a visual/physical example or description of why that would be? – tau Jan 28 at 19:58
Yes, essentially so a 2x10 beam will be eight times as stiff as a 2x5 beam but only twice as stiff as a 1x10 beam. Although this is based on a fairly simple model and in reality a joist is subject to loads other than pure bending. – Chris Johns Jan 28 at 20:12
The first thing to take into account is how stress builds in a material. This is rather intuitive and something we all know, but takes a bit of thinking to back it up mathematically. It's quite easy to get sucked into the world of 'Second moment of area' which is incredibly important for calculations, but not strictly necessary for understanding how it works (I hear screams of "heresy"..).
Essentially, when a beam bends, the bottom fibres are stretched and pulled apart (tension), while the top fibres crush together (compression). The beam will fail (e.g break) when either the top fibres reach their maximum compressive strength, or the bottom fibres reach their maximum tensile strength. Simple really! See my vquick sketch below:
So the implications of this is that at some point between the bottom and top fibres, there is a point where there is no stress (where it transitions from tension to compression). The maximum bending moment (engineer talk, not strictly important for understanding!) that a beam can take is limited by the compressive or tensile strength of a beam, and so working backwards we can work out the difference between a beam that is standing upright and one lying flat.
I've done a quick hand calculation with a few assumptions (for simplicity I've assumed the beam will fail in compression and has a compressive strength of 10N/mm^2 and changed the beam from 2"x10" to 20mm x 100mm). Starting with this, you can work out the 'area' of the stress triangle. You then multiply this by the area of the beam that this stress triangle occurs over.
As you can see, the 'taller' of the two beams has a larger stress triangle and thus can resist more bending! This is because more of the beam is located further away from the neutral axis (the point where the beam is neither in compression or tension)! Basically if you were to slowly increase the load, the top fibre of the taller beam would take longer to reach the killer 10N/mm^2 limit that I've given it.
I hope this is clear and simple, it's a little irritating to explain what is a relatively simple concept because there's so much ground to cover.
EDIT: I plan on re doing those sketches/calcs soon, hopefully with some colour. I quickly drew them up at work so didn't put much effort into them!
i dont see where you came up with those numbers (250N/mm and 50N/mm for the stress triangles. arent both triangles the same area but oriented differently? thanks!! – tau Jan 29 at 18:31
I will edit the diagram to make it clearer at some point tomorrow! Sorry for the relatively poor scribbles. But it's essentially geometry: The triangle in the weaker orientation is 10mm (half the depth of the beam) by 10N/mm (the limit), while the stronger is 50mm (half the depth of the beam) by 10N/mm (the same limit). – Smeato Feb 1 at 22:34
so the width of the triangle makes no difference? so the fact that the stronger 50mm triangle is only 10mm wide compared to the weaker 10mm triangle being 50mm wide has no bearing on this? thank you!! – tau Feb 2 at 22:26
All structural materials collapse when they suffer excessive deformations and stresses. If you stretch an elastic too far, it'll snap.
Joists are considered beam elements. This means that the primary internal force they need to withstand is bending moment. This bending moment is resisted by a force couple within the joist. The moment causes a rotation of the joist: the top of the joist will be compressed and the bottom will be stretched. This means that the force couple will be composed of the total compressive force on the top half of the joist and the total tensile force on the bottom half (which must be equal under simple bending).
Now, the moment due to a force couple is equal to the product of one of the forces and the distance between them. So, for a joist placed in the strong ("tall") as opposed to the weak ("wide") configuration, the distance will be greater, meaning that the requisite forces to withstand the bending moment will be reduced. Since, at the end of the day, what causes the element to collapse is excessive stresses, you want to minimize the total internal compressive/tensile forces (and therefore stresses) and therefore always put elements in their "strong" configuration.
A beam reacts to bending moment by actually bending a bit in the direction of moment. This bending creates strain in cross section of the beam, tension at lower face, compression at top face. Strain is directly proportional to stress.
Let's for simplicity assume we have bend a beam that has 1 cm2 of material on top and bottom and a web that is 10 cm wide and the max stress this material is capable of resisting is 1 kg/cm2.
So maximum moment this beam can handle is 1 kg x 10/2 at the top and 1kg x 10/2 at the bottom, put together it can handle 1 kg x 10 cm = 10 kgcm momentum.
If we widen the beam so that the web is 20 cm wide but same amount of material the new beam again has 1 cm2 material on top and 1 cm2 material on the bottom. But this beam can handle 1 kg x 20 cm = 20 kgcm momentum. Turning the joist upside-up will effectively increase its web width!
Why do we orient floor joists in with the longest side vertically? as in the shape of the letter "I" ?
AS mentioned in other posts, the name of the theory is "mass moment of inertia" of which there are whole textbooks written to explain.
However, quite simply, the formula for calculated this moment of inertia (for a rectangle like a 2x10 joist) is (bh^3)/12 or in English "B" x "H Cubed" over 12.
when the joist is oriented this way, its longer side (10") is oriented as the "H" (and the base is 2). Therefore when oriented this way, the wood resists loads much heavier than if it was "laid flat".
Try to bend a plastic ruler different ways. There is one way which will be very difficult. This is explained by moment of inertia!
The reason why I beams are so slim in the middle is that they are able to retain their strength in this orientation, but to save on weight, they are minimal in design (because the weight of the beam also adds to the forces that need to be calculated) So why would you make the beam any heavier than it needs to be if it is just as strong without the extra weight?
discard
By posting your answer, you agree to the privacy policy and terms of service.
