Engineering Stack Exchange is a question and answer site for professionals and students of engineering. It's 100% free, no registration required.
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
  3. The best answers are voted up and rise to the top
Why is that the shape of the tension test specimen a dogbone-like shape?
I know that it is so that the deformation is confined to the narrow center region and to reduce the likelihood of fracture to occur at the ends of the specimen. But why is this so important? Why can't a cylinder shaped specimen that has a uniform radius all along the specimen be used? Why does it, for example, matter if it fractures near the end (near the region where you clasped the specimen in the machine)?
share|improve this question
You can absolutely use a cylinder specimen, though you still need to taper it to control the failure location. This would be particularly convenient when you want to test real-world performance of rod-shaped members/components. But it seems less practical; your machine needs to be capable of exerting more force to test an object of the same rough size (mainly length) if the specimen is not flat, and the grips will no longer be simple clamps so may be a bit more involved design-wise and less convenient to operate. – Air Jan 25 at 19:30
You half-answered your own question. Preventing failure in the grips is important. Additionally, grips of tensile testing machines have teeth to achieve a sufficiently strong grip that can withstand the forces required to deform the sample longitudinally. The teeth typically cause plastic deformation of the gripped portion of the sample. The plastic deformation at the grips may change the material properties, and definitely changes the sample geometry. The sample geometry changes in such a way as to create stress concentrations in the gripped region. Both changes would contribute to an improper measurement if failure occurred at the grips in a cylindrical or bar specimen without enlarged ends.
share|improve this answer
Starrise gave a good explanation of the reasons why a dog-bone shape is important to the tension portion of a tension test, but there is another property that is typically measured at the same time: Elongation.
Elongation is measured by placing a gauge on the reduced section. It is important that the elongation occurs in this area so that the measurements are accurate. If the movement of the machine grips is used, then any plastic deformation of the grips will add to the elongation measured.
Not only do you reduce the diameter of the center section to ensure the break is in the section you're measuring for elongation, but you (ideally) also taper the reduced section slightly from the ends to the middle, so the break is in the middle and the elongation doesn't spread outside the area you're measuring. In practice, most machinists can't cut a specimen that precisely, so you just go with a uniform reduced section and hope for the best. – Mark Jan 24 at 8:45
discard
By posting your answer, you agree to the privacy policy and terms of service.
