Engineering Stack Exchange is a question and answer site for professionals and students of engineering. It's 100% free, no registration required.
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
  3. The best answers are voted up and rise to the top
I am practicing engineering drafting and sometimes I am near on finishing my work but suddenly I make a mistake. Is it possible to remove the ink? If yes, how? Where can I buy such tools? I am using a Staedtler's Mars Matic 0.5mm.
share|improve this question
How does ink have anything to do with drafting, since drafting is done on a computer? – Olin Lathrop Jan 21 at 12:26
Oh, sorry. I really don't know. I'm a first year electrical engineering student. – Cary Bondoc Jan 21 at 13:00
@OlinLathrop, hand drawing is still called "drafting" in the building engineering world. Just because computers have supplanted hand drafting doesn't mean the process has changed names. – grfrazee Jan 21 at 14:12
@grfr: My point is that no real drafting gets done with ink anymore, so this question makes little sense, or at least has little relevance to real life. – Olin Lathrop Jan 21 at 15:21
@OlinLathrup, colleges still teach hand drafting before computer drafting. It's a good way to learn about lineweights, perspective, and general arrangement of drawings. To me, it's like learning Reimann sums before learning the shortcut method for integrals - you need to know the basis before you just blindly use the best method. I still use hand-drawn sketches fairly frequently to convey ideas to my company's drafters and to clients. – grfrazee Jan 21 at 15:44
up vote 8 down vote accepted
To remove such ink it needs to scraped off, usually with a scalpel blade. This works well on thicker and more studier media such as film or vellum, but it will always be obvious where the erasure was made.
Depending on the amount of ink that needs to be removed and the robustness of the media, sometimes an ink erasure can work (such as a Staedtler blue ink eraser, Mars Plastic Combo), but again it will be obvious where the erasure was made. This can work on paper, but only with thicker robust paper.
If you need to present a drawing of professional standard, redraw the entire drawing.
share|improve this answer
I am using a buff paper like this will the Mars Plastic Combo work? – Cary Bondoc Jan 20 at 23:51
You will most likely end up damaging the paper. Also, you will erase some of the already printed grid lines. You could do a test on another sheet of paper. – Fred Jan 20 at 23:58
A quick Google search isn't turning up anything, as I more or less expected. Ink isn't meant to be erased, so I'm going to hazard that there is no product that will erase the ink for this pen.
Normally, the only "erasable" ink pens I see are the cheap, consumer-grade pens that use a more standard-grade ink (erasable is a relative term - I've never seen an erasable pen where you can totally remove the ink from the paper). Since the Staedtler pens are more professional-grade and use higher-quality inks, they are made to be indelible.
The tongue-in-cheek response to this would be "stop making mistakes." I know that's not really possible given that we're all human. However, when it comes time to inking, you should really be focused on tracing lines that you already know are correct. Inking is not the time to make changes.
+1 for tracing lines. Draft in pencil first - ink over the correct work, erase the pencil marks. – Chuck Jan 21 at 14:28
I have used sand paper on drawings before, with varied results. Experiment with a mix of grits on a scrap piece, and see if it will work with your paper. If no sand paper, try nail files. If nothing, redraw. Also Frixion makes magical erasable pens.
With a frixion, you can't really erase the ink. The ink has two phases, a color phase and a transparent phase. By heating or by friction (thus the name, I suppose) it changes to the transparent phase, by cooling to the color phase. Normally you change the phase by applying surface friction using a rubber, but you can also make it all transparent by storing at a hot place (I've heard the inside of a hot car is warm enough). And by cooling (in a freezer), you can re-show all erased (i.e. transparent) content again. No doubt this is very smart, but you should be aware of the limits. – Robin Jan 21 at 7:32
Not tested yet, but try using fabric whitener such as Bayclin.
So, bleach? Also, this isn't really the site for making unfounded suggestions. – grfrazee Jan 25 at 14:07
discard
By posting your answer, you agree to the privacy policy and terms of service.
